It is currently Tue Apr 16, 2024 3:10 am
Post new topic Reply to topic  [ 13 posts ]
PostPosted: Mon Jul 11, 2011 11:25 am
I don't know if anyone is considering this kit for their S30 but here are some shots from my partial install work this past weekend. I've also bought the 6-1 header from MSA, this is the version of the kit for that header. If you go with the 3-2 header, the kit supplies a 2-1 collector but the back-end is the same.
Here is the kit I received, very nicely done. All new hangers are supplied, one is pre-installed on the S-pipe. Your existing stock mounting bolts for the hangers will be re-used.
A thread on Classic Z showed a PDF of a Duramax diagram that designated the offset pipe as the inlet. Here is the result of going that route, not very pretty!
I noticed that with this arrangement, the Duramax stamping on the muffler was upside-down and that also did not look quite right.
Other comments on Classic Z went with the center pipe for the inlet so I swapped ends on the muffler with much better results.
I tilted the top of the muffler outboard about 30 degrees for a perfect fit into the curve of the fender. The mid-pipe will go on after the engine is installed and the driveshaft is in place.
And a final shot of the new exhaust tip peeking out.
Jim
Jim Arnett
Richardson, Texas
HLS30-15320 12/1970 (original owner)
ZCON 2015 Gold Cup - Street Modified class
PostPosted: Mon Jul 11, 2011 12:52 pm
Excellent!
Does the exhaust tip extend out beyond the bumper?
Frank
PostPosted: Mon Jul 11, 2011 1:19 pm
It is about 1/2" shy of the bumper vertical line, and could be adjusted some if I pulled the tip back out of the muffler tube (it fits inside).
Jim
Jim Arnett
Richardson, Texas
PostPosted: Mon Jul 11, 2011 1:30 pm
No, you want it shy of or even with the bumper, so it doesn't slash or burn you as you walk past.
Ask Paul Mackin! :lol:
PostPosted: Tue Jul 12, 2011 11:55 pm
I have the EXACT same system on my 240Z with the 6-1 header. I too was able to tuck the muffler up into the rear cavity, making a nice stealthy look. I had a little bit of an issue with the front flanges mating perfectly. The angles were slightly off and I had to push the exhaust system up under the diff with a jack, to get it to all line up against the bottom of the car neatly. Once it was up and bolted, it was fine. It does want to spring back down but the hangers keep it up nice and tight.
It definitely sounds louder than it looks. IMHO.
I am considering adding a flex section right after the header to reduce stress on the header gasket and studs. I am also considering adding a glasspack "bullet" style resonator in the system somewhere under the floorpan. I think it's slightly too loud for my neighborhood. Especially when my foot gets into the Webers a bit..
-Dave
76Z Turbo'd
72 In Progress---DONE!
PostPosted: Wed Jul 13, 2011 6:53 am
Looking good Jim!
Did I mention that I LOVE the color of your car???
:D
John Taddonio
1977 530Z
1984 300ZXT
zcarnut@hotmail.com
FB: Zccr zcarclubofrochester
PostPosted: Wed Jul 13, 2011 7:34 am
User avatar
ZCARNUT wrote:
Looking good Jim!
:D
wonder why John?? :roll: :lol:
Mike Tubiak
1978 Datsun 280Z - HLS30-438694
PostPosted: Wed Jul 13, 2011 7:57 am
Birds of a feather... ! :lol:
Dave - thanks for BOTH cautions.
Jim
Jim Arnett
Richardson, Texas
PostPosted: Wed Jul 13, 2011 8:13 am
Hey Dave!
So, what did you do differently from Jim, that the tailpipe extension
on your car should set so much higher into the recess in the rear
apron than his does?
All I can think of is shorter brackets and/or straps, but what do I know?
~Rick~
All Z Best,.......Kathy & Rick
1969 Z.CAR (#00013 10/69) 8/30/76
1969 ITSA.Z (#00171 11/69) 8/24/73
1970 OLD.Z (#06289 6/70) original owner
1971 510 2dr since 12/31/75
1969 1600 rdstr (our 160-Z)
1971 (#19851 1/71) sold
1975 75.Z (#01343 1/75)
PostPosted: Wed Jul 13, 2011 8:43 am
Getting the muffler to tuck up in there is a nice touch, I thought I was the only one, but good to see great minds think alike.....of course I have duel exhaust running back most of the way, then "Y" 'd in to a 3" outlet with 3" muffler. The only thing I would would change is have it more to the side of the diff. like yours. Nice job, and nice color, looking good.
PostPosted: Wed Jul 13, 2011 8:45 am
Show him your MSA scar, Paul! 8)
PostPosted: Wed Jul 13, 2011 8:49 am
:lol: well that was the old system, it's new and improved and smoooooth. :wink: The scar will be on display at our next event. :lol:
PostPosted: Wed Jul 13, 2011 9:02 am
Rick, the car jack will tuck the exhaust tightly against the bottom of the car as you tighten the hangers.
I agree, the color is great. What code is is?
-Dave
76Z Turbo'd
Users browsing this forum: No registered users and 6 guests
