1973 9mm connecting rods? http://forums.ctzcc.com/viewtopic.php?f=6&t=8891 |
Author: | Frank T [ Thu Jan 07, 2016 10:15 am ] |
Post subject: | 1973 9mm connecting rods? |
Need a full set of 1973 connecting rods for an L24 with 9mm bolts. Who's gottem? Frank T |
Author: | Frank T [ Wed Jan 20, 2016 12:45 am ] |
Post subject: | Re: 1973 9mm connecting rods? |
Let me be a bit more specific about this. WANTED: A set of L24 piston connecting rods which uses 9mm end cap bolts. These bolts were used on all L24 engines after about mid-1972, but surely onward from 1973. The connecting rods are slightly heavier and beefier than the rods which went before them, so they're preferred for engine rebuilds. If anyone has an L24 block laying around collecting dust and it happens to be later than mid-year 1972, you probably have the rods I'm referring to. Thanks! Frank |
Author: | SurferD [ Wed Jan 20, 2016 11:22 am ] |
Hey Frank I have some con rods but I don't know what engine they came out of, maybe a 2.6. You can have them if you want. |
Author: | Frank T [ Wed Jan 20, 2016 11:48 am ] |
Thanks! I'll make arrangements on PM to get up with you and grab those. Greatly appreciated! I realiZe the 260 had a longer stroke than the 240 had (79mm vs 73.7mm), but I could use those rods even if they were for a 260, anyway. |
