Engine runs fine for a while then quits http://forums.ctzcc.com/viewtopic.php?f=4&t=9755 |
Page 8 of 8 |
Author: | johnnyZ [ Wed Jun 10, 2020 9:50 am ] |
Post subject: | Re: Engine runs fine for a while then quits |
I recently contacted our Z friend and Z-Guru, Carl Beck about the suspected fuel pump issues that I have been having. He has responded to me today and contacted GMB directly, but also included the following link which included other Z owner posts with issues all too similar to mine. Hopefully, the end result will be that somebody provides a fix on these pumps that will give us reliable mechanical fuel pump operation! Amazon.com https://www.amazon.com/GMB-550-8040-Mec ... geNumber=1 |
Author: | 70 Z [ Mon Sep 21, 2020 8:43 am ] |
when i had my 70Z i would be driving along and all of a sudden it would just die----wait a while and it would start again---turned out to be the ceramic voltage "transformer" to step the volts to 6 volts to run the engine ---has run great since and still is |
Author: | Paul [ Sun Sep 27, 2020 11:36 am ] |
Just a thought....but have you checked the floats in the Carbs? They can get a pin hole in them, fill up, slowly drain, work and repeat,ect. and just one will stall the car. |
Page 8 of 8 | All times are UTC - 5 hours |
