Fuel injector conversion kit- old to new style http://forums.ctzcc.com/viewtopic.php?f=4&t=8913 |
Author: | Chris D [ Wed Feb 10, 2016 6:29 pm ] |
Post subject: | Fuel injector conversion kit- old to new style |
1991 Z32 N/A Does anyone know if you have to grind the plenum at the #1 cylinder when you install the conversion kit changing the fuel injectors from the early style to new style if you remove the top of the plenum? I know if you want to replace the injectors without removing the plenum you have to grind it to install the #1 new style injector but does that apply if you remove it? I have the Z1 conversion kit w/ new injectors as well as new gaskets for the balance tube. Thanks |
Author: | Rich@RDZ [ Sat Feb 20, 2016 8:00 am ] |
Post subject: | Re: Fuel injector conversion kit- old to new style |
Hi Chris, My name is Rich from RDZ Motorsports This conversion is NOT a level 1 install. THe Z32 is as complicated a car as they come and has a long list of classic car issues. That being said to answer your question in order to do the conversion it is 100% necessary to remove the plenum to complete this service. The area of the #1 injector must be ground to allow for the new injector style and to allow the connector to be plugged in. -Rich |
