freshening up old suspension http://forums.ctzcc.com/viewtopic.php?f=4&t=8461 |
Page 2 of 2 |
Author: | BFG [ Mon Sep 29, 2014 4:08 pm ] |
Post subject: | Re: freshening up old suspension |
What kind of paint did you use for all your pieces? |
Author: | SurferD [ Wed Oct 08, 2014 11:20 am ] |
BFG wrote: What kind of paint did you use for all your pieces? RustOLeum professional rattle can from Lowes or Home Depot. Gloss black and stainless for the strut and brake stuff. Springs are RustOLeum farm equipment John Deere green. |
Author: | SurferD [ Wed Oct 08, 2014 11:21 am ] |
I'm doing the rear stuff now. Darn you spindle pins!!!! I ended up just cutting the pins through the openings between the arm and knuckle. The pins laugh at my 12 ton press so it's off the the machine shop. |
Author: | Paul [ Sat Oct 11, 2014 8:51 am ] |
Do you have acetylene torches? Also, do you have an extra control arm bracket? The rear small bracket. [u] I have some one who needs, and I can't find. |
Author: | SurferD [ Sat Oct 11, 2014 9:12 pm ] |
Paul wrote: Do you have acetylene torches? Also, do you have an extra control arm bracket? The rear small bracket. [u] I have some one who needs, and I can't find. No acetylene just propane. I may have an extra bracket I'll check my parts boxes. |
Author: | SurferD [ Wed Feb 04, 2015 8:57 am ] |
Here's an update on the rear stuff. I couldn't just leave the rear diff looking bad. |
Author: | FM6 [ Wed Feb 04, 2015 11:10 am ] |
That looks great . . . . . how much do you charge ? ? |
Author: | SurferD [ Wed Feb 04, 2015 12:19 pm ] |
FM6 wrote: That looks great . . . . . how much do you charge ? ? I'm just doing this for myself but if you are really interested I could do yours too. What do you want done? |
Author: | FM6 [ Thu Feb 05, 2015 10:39 am ] |
I have just started doing mine with the help of a friend. Slow start just have the front apart now. Hoping mine comes out nice as yours as I am not that mechanically inclined. |
Author: | SurferD [ Thu Feb 05, 2015 5:23 pm ] |
FM6 wrote: I have just started doing mine with the help of a friend. Slow start just have the front apart now. Hoping mine comes out nice as yours as I am not that mechanically inclined. I didn't do as much on the front as you can see. The only reason I went this far is that spindle pin. I'm sure yours will come out nice. One thing I do advise is either media blast or Eastwood (or POR15) rust treatment stuff. You don't have to be that inclined. Just think of it as a big puzzle and get yourself a shop manual. |
Author: | SurferD [ Thu Feb 12, 2015 3:18 pm ] |
some more stuff |
Author: | SurferD [ Sun Apr 19, 2015 1:09 pm ] |
With the good weather It's coming together nicely. |
Author: | FM6 [ Tue May 05, 2015 2:02 pm ] |
I was able to get all rubber replacements for the rear including the mustache bar. I don't think I had to use polyurethane for anything yet. |
Author: | SurferD [ Tue May 05, 2015 2:20 pm ] |
FM6 wrote: I was able to get all rubber replacements for the rear including the mustache bar. I don't think I had to use polyurethane for anything yet. I ended up using poly as you can see. I tried getting the outboard bushings in but ended up destroying one. So instead of ruining parts poly was easier. I have new factory rubber for the four inboards and three outboards as well as the moustache bar that I'm not going to use. |
Page 2 of 2 | All times are UTC - 5 hours |
