It is currently Sat Apr 20, 2019 5:19 pm
Post new topic Reply to topic  [ 4 posts ]
 Post subject: Fuel issue
PostPosted: Fri May 02, 2014 12:58 pm
Car starts fine and runs fine 1st 2 starts.3rd start it's starving for fuel.Happens whether I drive 25 miles or 5 miles.Been doing it for a while.No one can seem to fix it,including County Line Nissan.oh, car is 84 300 zxt 50th AE.Lead mechanic []worked on car.
 Post subject: Re: Fuel issue
PostPosted: Sat May 03, 2014 6:49 pm
I would have them test the fuel pump. It way have pressure but poor flow.
PostPosted: Sun May 04, 2014 10:24 pm
Just so we understand ~ your Zenki Z-31 is stock, right? It has unmodified fuel injection?
There was a corporation-wide recall of those cars in the 1990s, I think, which replaced the entire fuel injection system AND modified the distributor, free.
Did your car get that yet?
Frank T
PostPosted: Sat May 24, 2014 8:10 am
I can spew out a bunch of possibilities, but it always comes down to....I fix it if it's in front of me. Just saying, but I take it you might be far away. First thing, when it acts up, make sure you have good spark. Those Dizzy's have a notion to fail a lot. Then the Air flow meters have been know to act up and fail, and of course check the fuel system for pressure. Check the pressure regulator. Or something computer controlled is acting up. ECM, corroded terminal wire, other sensors like TPS, CTS, so a lot to check, but think, spark, fuel, air. Hope this helps. Oh, do the wire wiggle test....if you wiggle a certain connection and it suddenly changes to running good, you found bad terminal. Good lucky
Users browsing this forum: No registered users and 3 guests
