LED Bulbs at RockAuto.com! http://forums.ctzcc.com/viewtopic.php?f=11&t=9162 |
Author: | RockAuto [ Fri Feb 10, 2017 12:40 pm ] |
Post subject: | LED Bulbs at RockAuto.com! |
Car restorers know answers to the question,[b]"How long does it take to replace an instrument panel light bulb?"[/b] range from [i]"five minutes"[/i] to [i]"I started taking apart the instrument panel two months ago, and I still haven't found that %!@# bulb!"[/i] Hard to reach bulbs and any other bulbs that you only want to change once, can now be replaced with new LED bulbs. Here are just a few benefits of using an LED bulb for your automotive lighting needs: *LED bulbs do not have a filament wire like incandescent bulbs, making them better equipped to withstand vibration *LED bulbs last longer, use less power and give off less heat compared to incandescent bulbs *LED bulbs typically give off more light and even come in multiple color choices *LED bulbs have fewer part numbers, making them more universal While LED bulbs do cost a lot more than incandescent bulbs, this is less scary when you consider that many incandescent bulbs start at less than $0.25 at RockAuto.com. It could be worth $10 or even $20 to avoid disassembling an instrument panel a second time. Find all types of bulbs, with choice of brands, at RockAuto.com under the "Electrical-Bulb & Socket" category for your vehicle. |
